SSL connection error ( Webmail : @msn.com )
eric1000
Post by eric1000 »
Hello!
I've tuned fine my MSN account,in PP,exactely as indicated in this site.
But it doesn't work:i can't connect to my account.
The error is:
"Msn
Échec de connexion SSL (Le module SSL est-il chargé ?)".
This module is the good one I downloaded just now.
Can I have a help?
Thank you
Re: webmail @msn.com
Do you have the SSL plugin installed? Here's how to check:
On the main menu, select Tools / Plugins
Look for SSL in the list and make sure it's enabled (ticked)
If it's listed, then it's possible that the error is occurring because you're behind a firewall that blocks SSL-based connections. Hotmail's POP3 service requires SSL, so instead of using POP3 to access your account, you should use Webmail instead: Edit the account and change the "Server Type" to "Hotmail/MSN/Live"
JRF
Re: SSL connection error ( Webmail : @msn.com )
Post by JRF »
eric1000 , welcome to the POP Peeper Forums ! Please reply .
1- did you download the latest SSL from the PP site SSL page (click here) ?
2- did you enable this plugin ? ( click Tools , Plugins , mark the SSL line , Close , restart PP )
3- if no result , or in any PP error msg : click the PP-error-yellow-button , click Copy , follow the instruction to report .
eric10000
Post by eric10000 »
Hello!
I am eric1000,but I can't login wth this account;so I create a new one.
I have followed all instructions.Same.
The error:
"Msn
Best regards
JRF
Post by JRF »
eric10000 , thanks for reporting , but it is still incomplete .
Please perform item #3 from my previous post .
eric10000
Post by eric10000 »
Now the eror is:
"--- Version ---
OS: Windows XP
POP Peeper: 3.8.1.0
Webmail: 3.8.0.8
SSL: 1.0.0.5
IMAP: 3.8.1.0
SendMail: 3.8.1.0
Msn [1: Hotmail/MSN/Live] ['pop3.live.com' (port: 993)] [SSL: 1]
Erreur inconnue : Essayez plus tard. (-11)"
OK.I understand:There is more than the apparentmessage of error.
JRF
Post by JRF »
eric10000 , thanks for reporting , please reply .
1- so I am assuming you have the SSL line marked (on Tools , Plugins) .
2- try to redefine the port , or define a new PP account (also have a look on the Hints) ,
according to the tutorial : Windows Live Hotmail / MSN {create a POP3 account
eric10000
Post by eric10000 »
I have tried to change the port 995,I have created a new PP account for my msn.
The error is:
"--- Version ---
OS: Windows XP
POP Peeper: 3.8.1.0
Webmail: 3.8.0.8
SSL: 1.0.0.5
IMAP: 3.8.1.0
SendMail: 3.8.1.0
Msn [0: POP3] ['pop3.live.com' (port: 995)] [SSL: 1]
Regarding the error you mentioned (when you had set the Server Type = Hotmail):
"Erreur inconnue : Essayez plus tard. (-11)"
This error can be resolved by following the advice here:
http://www.poppeeper.com/knownissues.php
If you would prefer to use POP3 -- are you at home or at work? Many workplace firewalls block SSL-based email connections.
eric10000
Post by eric10000 »
Thank you.I think it's OK by indicating my phone number in Hotmail account.
eric10000
Post by eric10000 »
Hello.
I still have the same problem with my msn.com mail address.
Username and password are correct: I go into my inbox with them, directly on the Internet.
I chose Hotmail / Outlook as a server.
And I get "unknown error".
What to do?
Best regards
Hi eric10000,
Sorry to hear you are experiencing problems again with your msn.com accounts.
You indicated receiving an "unknown error" message. To better assist you, please post back and include the complete text of the error message you are getting in POP Peeper by following the instructions in this Sticky: PP error messages: How to view them & copy/paste into your post.
In the interim, while awaiting further review of your topic, The Esumsoft Team recommends you review the following:
important information is provided regarding the Forums and POP Peeper program which new members need to be aware of, including cautionary notes about personally-identifiable information. Links are also provided to additional resources which explain how to perform a variety of tasks, as well as, the steps to take if you experience problems with the POP Peeper program.
Thank you and best regards,
eric10000
Post by eric10000 »
Hello.
The error message is:
POP Peeper: 4.4.1.0
Webmail: 4.4.12.0
SSL: 1.0.2.11
IMAP: 4.4.0.0
SendMail: 4.4.0.0
Profile Picture: 4.3.0.0
AntiJunk: 4.4.0.0 (disabled)
Spell Checker: 4.4.0.0 (disabled)
Web of Trust: 4.4.0.0 (disabled)
Msn [1: Hotmail/Outlook] ['imap.outlook.com' (993) SSL: 1] [Smtp: 'smtp-mail.outlook.com' (587) SSL: 2] [Consec: 5]
- Erreur inconnue : Essayez plus tard. (-1001)
(Translation: Unknown error: Try it later)
Regards
Thank you for posting the Error Overview information.
There was a Webmail plugin update recently that was for a similar error as this but you currently have that update that Jeff had referenced in the topic I've linked HERE.
I am not getting this error, however if this error remains persistent in your case you have the option of either waiting for Jeff to look into this to see see if another Webmail plugin update is needed (which I would recommend for now) or change (edit account) your MSN account protocols to IMAP (if you do this it is recommended to use both OAuth2 and enable Push/IDLE for MSN accounts).
eric10000
Re: SSL connection error ( Webmail : @msn.com ) SOLVED
Post by eric10000 »
I am very sorry.
I had to change my password for msn;because Windows 10.
I put the new one in PP.It is OK
Excuse me.
Best regards.
^ No problem at all eric10000 --- Thank you very much for posting back. Image
I've updated Hotmail so that it will report "invalid login/password" error instead of a generic error. This fix will go into the next release as needed (ie. webmail v4.4.13), but won't be released specifically for this fix.
