NEW SET OF ICONS PROPOSAL
Re: NEW SET OF ICONS PROPOSAL
Sorry, there's still no official way to modify the tray icons beyond the 3 different types that are currently available.
May I ask what you prefer about the other icons?
odji
Post by odji »
love this milou's icon, hope to see them in the next release =D>
Milou
Post by Milou »
Jeff wrote:It requires modifying the exe and I don't recommend or encourage it.
Hi Jeff,
I still use Axialis IconWorkshop to embed my own set of icons within the PopPeeper.exe file, just like I did with all previous versions of PopPeeper.
And I'm happy to see that it still works fine with version 4 ;)
Especially since v4 uses code-signing and modifying the exe would fail the check.
The modified .exe file launches normally on Windows startup, and Pop Peeper V4 works great with no problem of any kind.
However, activating the "About PopPeeper" windows shows a CRC "FAIL" (see image below).
This "failure" prevents Pop Peeper from detecting the version number, but everything works great.
Best regards
Emile FRANCO
efranco at free dot fr
** [Emile - I revised the original email address you included, for security/privacy reasons]
Reason: Modified email address in Signature line to prevent harvesting by spambots. (Re: Forum Rule # 7)
