Hi. I downloaded pp 4.01 and ran the installer. 4.01 was installed into a different new folder other than existing pp 3.8 folder Program Files (86)\poppeeper, which is what I think should have happened.
I copied all the files from the new folder to the old folder and it's running ok.
Ever heard of something like this?
Problem with installing pp 4.01
Re: Problem with installing pp 4.01
Do you remember where PPv4 was installed to?
The folder that you mentioned (Program Files) is the default folder. When you install POP Peeper, it will remember whatever folder you install it to and the next installation will default to that folder.
