RSS is it working for everyone?
- pop_pepper
Hi everyone, just a quick question but does anyone use RRS in Pop Peeper regulary. I do but my two RSS I use doesn't seem to want to work. I updated last night to the latest pop peeper but until now had not looked at it. is everyones working ok? if they are it must be my links.
Re: RSS is it working for everyone?
Hello pop_pepper,
The info below is what should be in the RSS Feed account:
Email address: rss@rss.rss
Login name: rss
Password: (leave this box blank)
Server type: RSS
Incoming server:
And, ensure the "Enabled" box is check-marked also.
Your settings for the account should match what is shown above. If you continue to experience problems, please post back and let us know what issues you're having.
Hope this helps.
Login name: rss
Server type: RSS
Incoming server:
Code: Select all
https://www.esumsoft.com/Forums/feed.php
Hope this helps.
- pop_pepper
ok cheers pete, will check. its weird because normally this one http://feeds.bbci.co.uk/news/uk/rss.xml usually works, but its underlines but checks if i manually check which isn't a problem.
- pop_pepper
all fixed thnks, i moved my rss to the top by inserting a 0 (zero) in the name so it checks first and it seems to of done the trick.
Glad to hear it's up and working again for you! One other note...it is recommended to set the POLLING INTERVAL for the account no lower than 10 minutes.
Setting it lower can often result in PP displaying the error message, "Error retrieving pages".
Cheers!
Cheers!
- pop_pepper
will set them to 20 minutes or more to be on the safe side, thank you
