Custom Weather URL BUTTONS - Force CELSIUS
Aeris Calendar: Tech support, suggestions, discussion, etc.
ZMEU.NET
Post by ZMEU.NET » Fri Sep 02, 2016 7:50 pm
I added my custom url http://www.accuweather.com/ro/ro/buchar ... ail-hourly but i get FAHRENHEIT instead of CELSIUS , despite i have checked use METRIC SYSTEM. So i need to add something to my url to force CELSIUS.
Re: Custom Weather URL BUTTONS - Force CELSIUS
Post by Jeff » Tue Sep 06, 2016 5:09 pm
I'm not sure if there's a url parameter or not, but on the top-right of that page, you can select celsius. I couldn't get it to work completely "as-expected" in either Aeris or my webbrowser, so if you select celsius and it doesn't seem to update: right-click on the page and select "refresh" and it should update to show celsius. This should also stay after Aeris is restarted.
brian112
Post by brian112 » Tue May 01, 2018 12:04 am
I added my custom url http://www.accuweather.com/ro/ro/bucharest/287430/hourly-weather-forecast/287430?lang=ro#detail-hourly but i get FAHRENHEIT instead of CELSIUS , despite i have checked use METRIC SYSTEM. So i need to add something to my url to force CELSIUS.
Hello. I found the solution to your problem regarding the AccuWeather feed. To change temperature units from Fahrenheit to Celsius you have to simply add the parameter
Code: Select all
&unit=c
or alternatively
Code: Select all
?unit=c
to the end of the URL. Here are some examples:
Code: Select all
https://www.accuweather.com/ro/ro/bucharest/287430/hourly-weather-forecast/287430?unit=c&lang=ro
Code: Select all
https://www.accuweather.com/en/gb/london/ec4a-2/weather-forecast/328328?lang=en-gb&unit=c
If you're using RSS feeds you can add the parameter
Code: Select all
&metric=1
or
Code: Select all
?metric=1
to show Metric units instead of Imperial units. Here are some examples:
Code: Select all
https://rss.accuweather.com/rss/liveweather_rss.asp?metric=1&locCode=EUR|RO|RO010|BUCURESTI|
Code: Select all
https://rss.accuweather.com/rss/liveweather_rss.asp?locCode=EUR|UK|UK001|LONDON|&metric=1
(this is a list of location codes in case you need them for an RSS feed https://pastebin.com/dbtemx5F)
Hope this helps.
Post by Jeff » Tue May 01, 2018 4:16 pm
Thanks, brian!
