How do you paste an image into new email in pop peeper
kktm
Post by kktm »
Is there a way to paste an image into the body area of the Compose new email window for pop peeper instead of just as an attachment? Its likely due to text only.
KK
Re: How do you paste an image into new email in pop peeper
Welcome to the forums, kktm.
You're correct that images cannot be inserted directly into the body of the email because POP Peeper supports plain text and not HTML for composition.
Although v5 doesn't add HTML composition, it does add a related feature -- you'll be able to attach images directly from the clipboard. So if you want to attach a screenshot (ie. from PrtScr or the snipping tool), you won't need to first save the file and then attach the file; POP Peeper will be able to add the image when you paste it. Or, alternatively, you can copy files from Windows Explorer and paste them (similar to drag & drop, but with copy & paste).
kktm
Post by kktm »
ok not quite the same affect but i can try that. Look forward to using V5 when it comes out.
Thank you
