Accessing GMX thru Entourage
orico
Post by orico »
Just recently, I've been having trouble sending emails through my Entourage account using GMX. I used to be able to send and receive with no problem. I still receive emails but cannot send them nor reply to the ones I've received. I always get the error message below. Can anyone advise???
Entourage cannot connect to the server. Verify that your computer is connected to the network.
Error: -3260
war1
Post by war1 »
orico,
Welcome to the POP Peeper forums. Are you using SSL security? Try alternate SMTP port 587
Have you try recreating the GMX account in Entourage?
Warren
orico
Post by orico »
Thanks for the welcome, and for your kind assistance.
Actually, now that you mention it, I'm no longer using a secure internet connection. Could that be the issue? Why will it receive, but not send?
I did try the SMTP port you suggested but got another error message, this time about timing out.
I also tried recreating the GMX account in Entourage, but with no difference in the result.
war1
Post by war1 »
There could be a temporarily problem with GMX SMTP server. Try using SSL and port 465 to send. I just tested with this configuration and it worked from POP Peeper.
Warren
orico
Post by orico »
It worked! :D You're my hero! Thank you so very much for your help! Have a wonderful day :)
