Thanks so much sportman40 -- based on what you have provided there does appear to be something wrong concerning what POP Peeper is doing in your case when you change font sizes.
So to confirm exactly the sequence of events that you have been doing to change font size from the main POP Peeper window (the PP Window that has your Accounts pane to the left and Message pane to the right):
1) Clicking on "Messages" in the main menu each time.
2) Clicking on "Select font..." option each time.
3) Changing ONLY the "Font size" each time.
4) Clicking on the "OK" button
And the two screen-shots you have posted on the previous page in this topic are the result of doing the same exact steps above for both font size changes?
If the answer is "Yes" to the question above -- then I'd say Jeff will need to look into this further. :?
sportman40
Post by sportman40 »
lakrsool you said to confirm exactly the sequence of events that you have been doing to change font size from the main POP Peeper window (the PP Window that has your Accounts pane to the left and Message pane to the right):
1) Clicking on "Messages" in the main menu each time. yes
2) Clicking on "Select font..." option each time. yes
3) Changing ONLY the "Font size" each time. yes
4) Clicking on the "OK" button yes
And the two screen-shots you have posted on the previous page in this topic are the result of doing the same exact steps above for both font size changes? yes
Many thanks sportman40 for all of your time spent looking into this.
I've contacted Jeff -- he'll probably be able to get back to us on this tomorrow some time. :wink:
sportman40 -- you're changing the font for the *account* list and not the *message* list. The distinction is the name of the menu. You need to make sure you use the "Messages" menu, not the "Accounts" menu.
There's another way to do it: right-click anywhere on the header of the message list (e.g. where it says "sender" like in the screenshot below) and choose "select font".
sportman40
Jeff the columns and message fonts are seperate can you give me a screenshot of both please ?
I'm not sure what other screenshots I can provide that would help.
Here's a short video of what you need to do, using the original method provided by lakrsrool:
https://data.esumsoft.com/Video/temp/PP ... ctFont.mp4
The key is that you need to select "Select Font" under the "MESSAGES" menu and not the "accounts" menu.
sportman40
Jeff is the short video is for making the columns not the messages ?
^ sportman40 -- the video that Jeff made for you is for changing the messages font size -- NOT the columns.
Follow the steps in the video and you will find that the font for messages will get changed exactly like the results that you see in the video example. :wink:
sportman40 -- something just occurred to me. You've been referring to "inbox messages" which lakrsrool and I have both been meaning to take as the messages list. But are you referring to when you're actually viewing the individual messages? That is, after you open a specific message?
sportman40
Jeff Column on the left
sportman40
inbox messages
To try and help clarify -- sportman40 has reported this as commented on this in the post HERE on previous page as compared to the subsequent post (where two font changes are compared) -- where you see that the only perceptible change between the two screen-shots was the Accounts Column font size differences.
ADDENDUM: A better comparison would be HERE where a bigger difference between font sizes was posted.
Ok, good. In that case, the video shows how to do it.
sportman40
Jeff do you have to do column fonts in one area and inbox messages in another to make it bigger ?
Yes -- the font size in the Accounts list (left-side) can be different than the font size in the Messages list (right-side).
sportman40
Jeff if you want column fonts in and inbox messages font bigger same font you do ?
If you want the Accounts list and Message list fonts the same, then you have to set both of them to the same font and size. Again -- there's a "select font" under both the "Accounts" menu and "Messages" menu. The "Select font" under the "Accounts" menu will change the font for the Accounts list (left side); and the "Select font" under the "Messages" menu will change the font for the Messages list (right side).
sportman40
If I want the Accounts list and Message list fonts the same, then you have to set both of them to the same font and size. show me how please
If you are happy with the font and size for the "Accounts" list, then do this:
1) From the main menu, select Accounts / Select font
2) Write down the "Font"
3) Write down the "Size"
4) Press Cancel
5) From the main menu, select Messages / Select font
6) Change the "Font" to what you wrote down in #2
7) Change the "Size" to what you wrote down in #3
8) Press OK
sportman40
If I want the Accounts list and Message list fonts the same, can I set both of them to the same font .one right click sender to make message and doing accounts select fonts for column on the left ?
