Yes, still 4 hours behind.lakrsrool wrote:And even set to your (correct) "EST" time-zone your saying that it's still 4 hours off (behind)?Dixon Butz wrote:It is actually options, general, region and time zone using the preview interface. Mine was already set to EST.lakrsrool wrote:You can edit the "time zone" values in the "Options" settings (click on "gear" icon top-right of inbox interface) of the Hotmail account and from there click on the "Account details (password, addresses, time zone)" option within the "Managing your account" settings (top-left) of that Hotmail "Options" interface.
If so, apparently just another "improvement" with the "new" Hotmail interface.![]()
Issues with Hotmail/Outlook.com (-31 error)
- Dixon Butz
Re: Issues with Hotmail/Outlook.com (-31 error)
That's interesting because my time-stamp involves using the "old" interface (w/out "preview) and is correct for my time-zone.Dixon Butz wrote:Yes, still 4 hours behind.lakrsrool wrote:And even set to your (correct) "EST" time-zone your saying that it's still 4 hours off (behind)?Dixon Butz wrote:
OK, I just tested with a "test" account I have using the "new" Hotmail interface (w/ Preview) and my time-zone stamp is working fine (using PST).
So I guess we maybe can't blame the "new" interface after all.
Addendum: I switched the "test" account to EST and I get the correct 3 hour later time difference in my case.
- Dixon Butz
The timestamps are correct in the preview webpage.
The timezone is correct on my PC.
I changed the timezone on preview to CST. I'll see if it changes anything. Nope. Just got a mail in PP stamped 234PM. Wait what? It's 704PM here.
Changed back to EST and off 4hrs again.
The timezone issue should be fixed now, WebMail v4.0.23.
Same procedure as before to update the webmail plugin.
However, existing messages won't update their information after you update the plugin. You'll have to use the trick to remove messages and force PP to download them again:
http://www.esumsoft.com/products/pop-pe ... veFromList
- Dixon Butz
Thanks Jeff - The new 4.0.23 works great! Awesome job, as always.Jeff wrote:The fix for the delete issue was just released in WebMail v4.0.22; here's how to get it:
1) From PP's main menu, select Help/About
2) Make sure that both "automatically check for updates" and "auto-update webmail plugin" are enabled
3) Press "Check version"
4) It should auto-update
5) I recommend exiting/restart PP to make sure that the updated webmail plugin is being used.
Please check that deleting works for those previously affected accounts and let me know that it works for them (or not).
