POP Peeper v3.3
POP Peeper v3.3
POP Peeper v3.3 is now available:
http://www.poppeeper.com/download.php
Changes
- Fix: "Buffer overrun" caused crash for some users on initial check mail
- Fix: Ssl related crash for some users
- Fix: Timestamps issues for non-English users on some webmail services
- Fix: Timestamp issue for pop3/imap-based messages that don't conform to RFC in certain case
- Fix: Prevent message list window from overextending its expected height
- Fix: Toolbar button widths will resize according to system fonts (ie. normal/large/extra-large)
- Fix: Delete-All (toolbar) now only marks visible messages; not necessarily all messages in viewed account(s)
- Fix: Smtp: potential problem (wrong error message) when an invalid auth is used
- Fix: Tooltips with CRLF (ie. Sender) would sometimes lose CRLF
- Fix: Imap: Messages with certain header format caused timeout (rare)
- Fix: Server addresses containing leading\trailing spaces are trimmed (caused unknown host errors)
- Fix: Forward and Reply-All toolbar buttons would not work as expected when viewing a loaded message
- Imap will not engage idle if autocheck is currently disabled and checkmail is performed
- Smtp: Removed blank line at start of sent email
- Added "View Full Source" to View Message menu
- Added Gmx as a recognized email provider (to help fill in login and server details during Create Account)
- Installer: "Run" on finish page disabled for Vista users to prevent running with Admin privs
- Email Files (.eml) can now be associated with POP Peeper
- Size Column is right-justified
- View-Accounts, Read and Delete buttons have been moved above the message list for easier access
