Outgoing gmail issue
Domitilla
Post by Domitilla »
I'm having a problem with my gmail on the iPhone . The error I'm getting is when I open my email a popup thing comes up and says that connection to outgoing mail server SMTP.gmail.com has failed. Does anyone know how to fix this. Because I cannot send email and its getting pretty frustrating. I apologize If this is an easy fix im just not sure how to do it and its driving me nuts.
Thanks in advance
Welcome to the POP Peeper forums, Domitilla.
I don't have an iPhone, but there is a specific faq from gmail regarding the iPhone setup:
http://mail.google.com/support/bin/answ ... swer=77702
although it doesn't seem to suggest anything unexpected.
war1
Post by war1 »
Is your outgoing server settings port 465 or 587? SSL enabled? Outgoing server authentication enabled?
Also, change SMTP.gmail.com to smtp.gmai.com Case should not make a difference, but it's worth a try.
Warren
