www.nyc.com
NYCzzzz
www.nyc.com
Post by NYCzzzz »
Since gmail now handles nyc.com is there a way to configure it through POP PEEPER?
I tried using it with gmail as the server type but it doesn't work.
Since they switched to the new gmail interface, When I log into the account the address in the address bar reads http://mail.google.com/a/nyc.com/?AuthE ... =SSO#inbox
Is there some way to make this work in POP PEEPER?
See this faq for accessing GMail for Domains accounts in POP Peeper:
http://www.poppeeper.com/faq.php?q=GMail_Domains
Although, it seems to use a different interface than typical gmail-hosted email domains and I can't guarantee that it will work. It's also possible that you can use pop3 and imap access, but again, considering this looks to be a special partnership with nyc.com and gmail, it's possible they've disabled that as well.
NYCzzzz
No go
Post by NYCzzzz »
Tried just about every combination I can think of. No go. Thanks.
war1
Post by war1 »
NYCzzzz,
Welcome to the POP Peeper forum. If you want to access with POP3 access, use pop.gmail.com, port 995, SSL enabled.
If you want to use IMAP, use imap.gmail.com, port 993 and SSL enabled. You login address is what your domain administrator gives you. Check with the Admin.
Warren
NYCzzzz
WAR1 ROCKS!!! THANK YOU!
Post by NYCzzzz »
War1!!! You ROCK!!! POP worked like a charm. THANK YOU!!!! :lol:
