duplicated emails
fredfmah
duplicated emails
Post by fredfmah »
Dear Gurus,
please forgive if this is not a question for pop peeper. I'll explain.
I have two accounts one with orange and one with yahoo and they have worked very well with poppeeper and still do.
About a month ago I updated to OpenOffice 3 from OO 2.4. and a new account appeared in PP called OOdocs.
I had taken the time to fill in their questionnaire which turned out to be much longer than I expected and maybe I had unwittingly formed this mail account
My problem is every email that arrives at yahoo also arrives at OOdocs and so I have popeeper listing two emails that are identical..
I'd be most grateful for any help to eliminate one of the accounts, I think the one to get the chop should be Oodocs.
Bye and thanks
Fred
JRF
Re: duplicated emails
Post by JRF »
fredfmah , welcome to the POP Peeper Forums ! Please reply .
Are you saying that in the PP Accounts panel (the region to the left of the PP main window screen) there is a line named OOdocs ?
If so this is very strange , there is no notice another application creates accounts inside PP :
-- then I ask you try to remember if you did create it (following some direction ??) ,
-- please give all other details you think may be related ,
-- if possible take jpg screenshot(s) , and use the Upload Attachment function on your reply ,
-- and by now the better is to maintain it for further investigation , but to stop its activity :
right-click over the account-name , select Edit , UNmark the box "Enabled" , click Update .
fredfmah
Post by fredfmah »
Thank you for the reply and I have attached three snaps-
OOdocs001 is todays mail
OOdocs002 is the OOdocs version of the top listed
OOdocs003 is the same, but read from Yahoo
I hope this may be what you asked for.
Fred Madrid
PS I havent zapped the OOdocs yet, maybe you will need a little more information
Bye Fred
JRF
Post by JRF »
fredfmah , OK , thank you , your pics will be useful to clarify this .
1- more two pics requested , please : edit each account > General tab >
mask your 2 usernames with "X" > take the shot > click Cancel .
2- you may disable OOdocs account now : just UNmark the tick in front the account name .
Side-note/tip on Security :
-- the recommended Viewing Options are :
-- then , for an easier operation , you could have the Toolbar like :
I think what JRF is after is to see if both accounts are identical (ie. both are logging into the same Yahoo account).
I suspect that they are.
My advice -- delete the OOdocs account and add your previous account (orange) again.
That's a strange phenomenon. Very strange...
