POP Peeper v3.7 released
POP Peeper v3.7 has been released. Download the new version here:
http://www.poppeeper.com/download.php
There is also an update to PPTweaker:
http://www.poppeeper.com/PPTweaker/
POP Peeper v3.7 is primarily a maintenance release. It is an optional
update, but it is recommended if you use any Imap accounts with SSL/TLS
as a major bug was fixed related to that type of account. Many other
general bugs were fixed as well, including the ability to view multiple
attachments that have the same filename.
Changelog:
- Additional version information presented in webpage when using "download" button
- Option to flash NumLock LED for new message indicator
- Option to open URLs in new browser window added in v3.6 (PPTweaker)
- Option to define the number of consecutive errors that causes error tray icon (PPTweaker)
- Option to prevent attachments from being included in the saved .eml file for sent messages (PPTweaker)
- Enhancement to Ini Manager allows add and delete (run: poppeeper.exe -ini)
- Automatic ini backup to prevent loss of data when ini file is corrupted
- Error popup if email client cannot be run (Windows 7 does not provide a default email client)
- Run Client for multiple accounts with new mail will open each account's *unique* client
- SMTP: includes headers for In-Reply-To and References
- HtmlRef.dat file updated to include additional Greek characters
- Logic for retrieving auto-update info has changed to lighten load on web server
- Fix: Occasional crash under certain conditions when using accounts as Imap/SSL/Idle
- Fix: In certain situations, POP Peeper would show duplicate messages on initial startup
- Fix: Imap: Processing extended capabilities after login
- Fix: RFC822 messages containing multiple attachments with same filename (usually images) will all appear
- Fix: SendMail, alert when attempting to send an attachment that does not exist
- Fix: When editing account, pressing update button will alert to missing required fields instead of disabling update
- Fix: PPInfo.txt will be saved to data folder instead of installation folder (UAC issue)
- Fix: RSS: SMTP is not enabled by default when creating a new RSS account
- Fix: When creating a new account (single) and SendMail plugin is not loaded, updates to the account were prevented
- Fix: SendMail: minimum size constraints for dialog window
- Fix: Imap: TLS is allowed if server supports logindisabled capability
- Fix: If using per-account sounds and retrieving number of messages only, account sound would not play
- Fix: Tooltips added for Outbox buttons (view/delete message)
