PPLC 3.x or English language template
Tiggz
Post by Tiggz »
Hi Jeff
I am looking for an English language template for PP 3.7 or PPLC 3.7. Is one of these still available?
Regards
Re: PPLC 3.7 or English language template
The latest PPLC is still at v3.4. Do you think that an update is necessary?
Tiggz
Post by Tiggz »
Hi Jeff
Not really :mrgreen: . Meanwhile I found the old/new untranslated strings for the german language file by using Reshacker.
The german language file for PP 3.7 is attached.
Regards
The existing German translation is already at the latest PPLC v3.4. While it's technically possible to manually add some of the text that has been added since then, it's not very convenient. What did you change in your file?
Tiggz
Post by Tiggz »
Hi Jeff,
*New attachment*
I changed the word "Editieren" to "Bearbeiten" (10 times). "Bearbeiten" is standard in Windows and any other program.
The following strings were not translated:
{DIALOG_CONTROLS}
[257]
1568 INI Speicherort:
1561 Automatisches Backup der INI-Datei
{MENU}
32981 Sicherung/Wiederherstellung starten
<SendMail>
{DIALOG_CONTROLS}
[1002]
1038 Kodierung:
1040 Antworten: Original-Nachricht mit ">" einrücken
1041 Weiterleiten: Original-Nachricht mit ">" einrücken
{Menu}
[1004]
-1 &Edit.*.&Bearbeiten
57643 &Rückgängig\tCtrl+Z
57635 &Ausschneiden\tCtrl+X
57634 &Kopieren\tCtrl+C
57637 &Einfügen\tCtrl+V
32798 &Löschen\tDel
32774 Alles au&swählen\tCtrl+A
Can you please email the file to me (support at poppeeper dot com)? That way I have a record of where the file came from.
Tiggz
Post by Tiggz »
Jeff wrote:Can you please email the file to me (support at poppeeper dot com)? That way I have a record of where the file came from.
Hi Jeff,
I just sent it to you. It contains some additional changes:
1) These string was missing in the language file:
{MENU}
32951 Als neue Nachricht bearbeiten
32952 Als neue Nachricht bearbeiten
2) Some corrections of the old language file for PP 3.4
Regards
Pr0fessor
Re: PPLC 3.8 or English language template
Post by Pr0fessor »
Hi Jeff
I am looking for an English language template for PP 3.8 or PPLC 3.8 for a translation....
i want to update the german language file.... :wink:
Tiggz
Post by Tiggz »
German language file for PP 3.8 is attached.
Regards
Pr0fessor
Post by Pr0fessor »
Thank you^^
bist aber fix :D
Tiggz
Post by Tiggz »
- It's not possible to translate the label of the new toolbar buttons "Sent Mail" and "Archive".
- It's not possible to translate the context menu of the toolbar. This was due to a technical issue with that particular context menu:
http://www.poppeeper.com/Forums/viewtop ... ize#p17940
