Uncheck "U.S. FTC" makes Pop Peeper to crash
Tomas_Sweden
Post by Tomas_Sweden »
If I uncheck "U.S. FTC" Pop Peeper crashes with error code: 0xc0000005
If I Enable it again, Pop Peeper work as it should.
I have the latest version 4.0.1.0 and webmail 4.0.14.0.
I attach a picture of that I mean.
Tomas
Re: Uncheck "U.S. FTC" makes Pop Peeper to crash
I'm not able to duplicate the problem. At what point does POP Peeper crash? e.g. as soon as you uncheck it, when you perform a checkmail, when you try to report spam, etc.?
Tomas_Sweden
I was then I were trying to view message (Retur), now is it then i uncheck "Knujon.com" and "U.S. FTC" and after that I try to view message (Retur)
Tomas
Ok, I'm able to duplicate it now -- if NO reporting services are enabled, then PP will crash when you try to view a message (whether the "report spam" button in on the toolbar or not). I'll fix this.
In the meantime, just keep at least one of the services enabled and you should be fine. There's really no reason not to disable all of them, POP Peeper won't use the services unless you specifically report an email.
AidanOrton
Post by AidanOrton »
Hi
How can you add a service back in if you've deleted them all out?
The New button is disabled.
Thanks,
Aidan
Thanks for reporting this, Aiden. And I apologize for the problem.
The "new" button becomes (incorrectly) disabled if no service is selected in the list. I have just fixed it for the next version.
If this is something that you don't want to wait for, email me and we can insert a service manually so that you can get it working again.
AidanOrton
Hi Jeff
First off thanks for a great little app. I'm still currently looking at it in freebie mode, but I do dig into my pockets for apps which genuinely prove useful.
Having said that, I now can't use it because of this issue. I can get by because I still have Thunderbird installed to periodically pull down all my mails, but it is a pain.
It's also started popping up to say I'm out of my pro evaluation period and have to pay now!
I don't really want to be forced into it at this time.
If you can help it would be great, if not I can hang on. I'm a developer too, though more web apps, but not afraid to get in and hack something.
Aidan
I've sent you an email with further instructions.
AidanOrton
Sorted it, good stuff thanks.
=D>
