Evaluation Box & MyWOT
tigerwokie
Post by tigerwokie »
Hi, is there a way to remove the Evaluation Box and to disable the MyWOT function in V4 ? Thanks.
Re: Evaluation Box & MyWOT
Hi tigerwokie
Open PP > TOOLS > PLUGINS, just uncheck the boxes beside Web of Trust and AntiJunk, then click [OK].
tigerwokie
Thanks Pete. That was helpful.
You're welcome.
I'm re-evaluating the current settings of WOT so that maybe it won't be quite as aggressive, and also to make it easier to add sites to the ignore list. By default, not all clicks should activate the WOT prompt, it's only for low-trusted and low-confidence links. Do you happen to remember any websites that caused the prompt?
tigerwokie
Sorry I don't remember the specific sites, but most of them are on/from Groupons and some online merchants ...etc . It was just too many prompts and mouse clicks. Thanks.
