Pro version , why the force?
pop_pepper
Post by pop_pepper »
why does my pop peeper tell me i need to upgrade? and then when i try it tries to make me down load the pro version...... :roll:
Re: Pro version , why the force?
Well, it tells you that there is an upgrade because there is a new version and you've enabled "automatically check for updates." The Pro version will revert to the free version after the 30 day trial.
pop_pepper
ok thanks
