Gmail is not working today
majekho
Post by majekho »
Please help. Thanks
arcadian
Re: Gmail is not working today
Post by arcadian »
Having same problem on all 12 accounts, getting "Error try again later" -10....
Hope you can help
chrisdoc365
Post by chrisdoc365 »
I am also having this problem
Popylu
Problems checking mail
Post by Popylu »
I have lately some problems with checking my email via my gmail account, see comments below.
POP Peeper: 4.0.1.0
Webmail: 4.0.14.0
SSL: 1.0.1.8
IMAP: 4.0.1.0
SendMail: 4.0.1.0
AntiJunk: 4.0.1.0
Spell Checker: 4.0.1.0
Web of Trust: 4.0.1.0
Gmail (luckerhof.nico) [10: GMail] ['imap.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1]
Onbekende fout: Probeer later opnieuw. (-10)
[Unknown error: Please try again later. (-10)]
Do you solve this problem?
Many regards,
Reason: This topic post merged with other similar posts made today and part of error message translated to English for other members' benefit.
Good morning everyone and welcome to our newest member, Popylu!
Thank you each for reporting your problems with Gmail - which at this time, appear to be nearly identical. We are presently looking into this issue and hope to have more info available later on.
[For others experiencing this Gmail problem - please read below]
To better assist the PopPeeper Team with determining the problem and providing a resolution, please follow the instructions below:
1. When posting here to alert us that you are experiencing a problem, please be sure to include the specific error message text you are receiving in PP, and other information like what is shown in Popylu's post above.
(To do this, please see lakrsrool's instructions provided HERE).
2. Please indicate how you are accessing the affected accounts. (i.e. Gmail, POP3, or IMAP).
3. Confirm whether or not you can access the affected accounts on-line.
(Please remember NOT to post your actual email address(es). They can be harvested by spambots).
** I have already contacted Jeff about these multiple reports as well.
Thank you for your assistance in this regard and patience as we work toward a resolution for the problem!
chrisdoc365
I access Gmail via Webmail
POP Peeper: 4.0.1.0
Webmail: 4.0.10.0
SSL: 1.0.1.8
IMAP: 4.0.1.0
SendMail: 4.0.1.0
AntiJunk: 4.0.1.0
Gmail [10: GMail] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0]
Error: Try again later. (-10)
The GMail error has been fixed in WebMail v4.0.15. You can either wait for it to auto-update (usually within 24 hours), or you can force an immediate update:
1) From POP Peeper's main menu: select Help / About
2) Make sure that both "automatically check for updates" and "auto-update webmail plugin" are enabled
3) Press the "Check Version" button
For other options, including manual update, please see this FAQ:
http://www.esumsoft.com/products/pop-pe ... atewebmail
Details: GMail now requires confirmation when using the Basic/HTML version of GMail.
arcadian
Post by arcadian »
Many thanks as always Jeff what would we do without you.... ! =D> :D
j00
GMail - Error: Try again later. (-10)
Post by j00 »
Hi.
I'm having this problem for about 9 hours.
OS: Windows 7
POP Peeper: 4.0.1.0
Webmail: 4.0.14.0
SSL: 1.0.1.8
IMAP: 4.0.1.0
SendMail: 4.0.1.0
Gmail [10: GMail] ['imap.gmail.com' (993) SSL: 1] [ClientSend: '' (0) SSL: 0]
It was working. I didn't change anything and don't use firewall.
Reason: This post moved from the 2 year old topic to which it was originally appended to this topic as the problem being reported is the same as others.
Re: GMail - Error: Try again later. (-10)
Welcome to the PP Forums, j00!
Please read Jeff's post above regarding the problem you are reporting and the instructions for resolving it. A Webmail update has been released to correct the issue.
Also, it is a good idea to first look at recent forum posts to see if any others have posted about a problem similar to yours, rather than posting an inquiry to a topic which is over 2 years old. Often times, a resolution will already have been posted.
Thank you & best regards,
chrislla
all G mail giving error
Post by chrislla »
This started happening yesterday night. All G mail account can not be retrieved/accessed. There is no change in passwords. Can login all gmail with regular web login in Mozilla.
Reason: This post was merged with existing topic for which a problem resolution has already been provided.
Re: all G mail giving error
Hi chrislla and welcome to the PP Forums!
Please read Jeff's post above which provides details of how to resolve your Gmail problem. A Webmail update has just been released.
Also, it's preferable to first check the Forums to see if others may have already posted about an issue you may be experiencing, before creating a new, separate topic, as a solution could already have been found.
chrislla
Post by chrislla »
In the morning there were no updates so I posted. Now I See updates and update to new version.
Now ALL Yahoo mail stopped working.
arrrrrrrrhhh.
I will reinstall/update and restart pc and try.
chrisdoc365
Thanks Jeff
chrislla wrote:In the morning there were no updates so I posted. Now I See updates and update to new version.
arrrrrrrrhhh.
In regards to your comment that "All Yahoo mail stopped working", then I'm presuming you're getting errors which you can view by clicking on the "yellow exclamation" at the bottom right of Pop Peeper.
CLICK ON YELLOW EXCLAMATION TO GET ERROR OVERVIEW WINDOW
PP Error Overview.png (1.5 KiB) Viewed 18857 times
To provide the error information in this topic then click on the "Copy" button, click "OK" then post a reply here in this topic to paste the error (place cursor in reply, right/click in your reply to this topic and select "paste" or alternatively you can press CTRL+V to paste the error).
Thank you.
j00
Post by j00 »
Thanks, everything is ok now.
chrislla
Post by chrislla »
works fine today. Looks like re-install and reboot all things were not needed. But works now.
petspy
Post by petspy »
gmail stopped working overnight (june 4-5)
aol and yahoo continue to work as before.
I will follow this discussion for a solution.
POP Peeper: 4.0.0.2009
Webmail: 4.0.8.0
SSL: 1.0.1.8
IMAP: 4.0.0.0
SendMail: 4.0.0.0
petspy [10: GMail] ['imap.gmail.com' (993) SSL: 1] [ClientSend: '' (0) SSL: 0]
EDIT: I'm back after update and gmail is working fine =D>
Glad you got the problem resolved, but I noticed a couple of other things worth mentioning:
1) You're using an old beta of v4.0 -- v4.0.1 is available here:
http://www.esumsoft.com/download/
(edit: oops: didn't notice that you already updated)
2) There was an early version of the SSL plugin v1.0.1.8 which didn't have the CRC embedded in it, so that's probably why it's failing. You probably don't need to worry about it, but in case it bothers you, you can download and install it again:
http://www.esumsoft.com/products/pop-pe ... ugins/#SSL
