Can't login to google accounts
007me
Post by 007me »
since last week i can't login to google accounts. Getting this error:
OS: Windows 8 (x64)
POP Peeper: 4.0.1.0
Webmail: 4.0.16.0
SSL: 1.0.1.8
IMAP: 4.0.1.0
SendMail: 4.0.1.0
--- Web Test ---
Result: 200
Error:
Time: 13:43:44 - 13:43:45 (1 s) (+0300)
Data: Sun, 07 Jun 2015 03:43:45 -0700
Stam [10: GMail] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0]
Login Error: Check your Login Name and Password.
Udi - gmail [10: GMail] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0]
Error: Try again later. (-10)
Udi-postmaster [10: GMail] ['' (0) SSL: 0] [WebSend: '' (0) SSL: 0]
Re: Can't login to google accounts
Hi 007me,
Sorry to hear of the issue you're having with Gmail. At the present time, I'm not seeing any service disruptions being reported for Gmail, which might account for your problem, so I have a couple of questions for you to get started:
1. Are you able to log-in to the affected accounts on-line without any problems?
(NOTE: If you are automatically logged-in, you need to first log-out, and then log back in. Gnail could be requesting a captcha or other info).
2. Have you considered changing your accounts to use IMAP access instead of Webmail (i.e. Gmail) ?
Switching your accounts to IMAP may well resolve the issue you're experiencing. IMAP is generally the better protocol to use and in PP version 4 it is relatively simple to make the change. (See Jeff's quote/instructions/link below):
[Quote from Jeff]
All you should need to do in PPv4 is change the server type to IMAP and PP will make the other changes, but you may need to refer to step #3 in the IMAP FAQ link shown below.
http://www.esumsoft.com/products/pop-pe ... =GMailImap" onclick="window.open(this.href);return false;
Thank you and best regards,
007me
Post by 007me »
Thank you. Working.
You're welcome.
Cheers!
