Will PopPeeper v4 run on Windows 10?
Will POP Peeper PRO run under Windows 10 x64? I'd like to purchase it but only if it runs with no problems under Windows 10.
Reason: Modified topic title for better attention.
Re: Will PopPeeper v4 run on Windows 10?
Hi streetwolf and welcome to the PP Forums,
To answer your inquiry, YES, PopPeeper will run on Windows Operating Systems 2000 and later, including Windows 10.
Please review Jeff's official Announcement about PopPeeper version 4.
You have the options of purchasing PP Pro v4 outright, or you can simply download it from the esumsoft.com website and try it out FREE for 30 days to see if it meets your particular needs. Prior to the end of the trial period, you may purchase it.
PopPeeper Pro v4 will automatically revert to the FREE version of the program at the end of the trial period. The reversion just means that the premium features of PP Pro v4, such as, Spell Checker, Antijunk, and WOT will be disabled, but the basic core functions of the PopPeeper program will continue to work normally.
If you should experience any problems installing and/or using PopPeeper, there is an extensive FAQ section available at the PopPeeper website, esumsoft.com SHOWN HERE, as well as, the PP program's own Help Files.
In addition, you can search the Forums here to see if another member has already posted about the issue, or you may also post an inquiry as well.
PP users experiencing a problem are encouraged to first utilize the aforementioned methods to resolve the issue, before contacting PopPeeper Support using the PopPeeper Support Contact Form.
Please feel free to post back if you have any questions.
Yes, POP Peeper will run on Windows 10.
