Keeps the wrong index when marking lines.
samopedia
Post by samopedia »
Hi all
Thank you for the great PopPeeper.
Problem:
Marks/selects wrong set of lines/emails.c
Keeps old/wrong index of the selected line when marking lines of emails in the list view.
Reproduce by:
1- View all accounts
2- Click on Date/Time column header (Sort list by date/time)
3- Mark the first email (first line)
4- Click on "Sender" column header (Sort list by sender)
Marked email or the line changes position in the list and should have a new index.
5- Hold down SHIFT and mark an email/line few line under the marked line.
It should select from 1th marked line and the line marked by SHIFT down.
BUT it does mark/select from beginning of the list to the last selected/marked line.
I guess it keeps the line index (0) even though the line (after selecting Sender) gets new position and should have new index.
Windows 7 Ultimate SP1
PopPeeper 4.0.1.
Best Regards
/Samo
Re: Keeps the wrong index when marking lines.
Thanks for the detailed procedure to duplicate it. I was able to reproduce the problem and fix it. The fix will be in the next release (v4.1/beta 3)
