Password window
flechedargent
Password window
Post by flechedargent »
Is it possible to make the password window behave like a real window ?
It may sound strange, let me explain :
I'm using POP Peeper on a laptop with Windows 8.1.
When I set a password for POP Peeper, a window open when I launch the program to ask for the password.
The problem is that the password window doesn't appear in the taskbar, so sometimes I have to reduce all the opened windows to the taskbar, to find the POP Peeper password window if another window covers it.
Thanks,
flechedargent
Re: Password window
Welcome to the POP Peeper forums, flechedargent.
I'm not able to duplicate this behavior of the password confirmation appearing below other windows, can you tell me:
1) What version of POP Peeper you have (look under the main menu: Help / About)
2) What you're doing to see the password confirmation window. ie. double-clicking on the tray icon; running POP Peeper from a desktop icon [is PP already running or are you launching it for the first time?], etc.
OR, are you saying that the password window does appear on top, but if you switch back to another window, the password window is just hard to find?
As a work-around until I can duplicate it and see what's causing the problem -- you can use Alt-Tab to find the POP Peeper password window, which might be easier than minimizing everything
flechedargent
Re: Password window
Hi Jeff,
The password window does appear on top if I just launch the program, but since I'm doing a lot of things while launching POP Peeper, I often end up with others windows covering the password window.
So the problem is not that the password window doesn't appear on top, the problem is that I can't retrieve it in the taskbar. :( (Your tip with Alt-Tab works fine, thanks, but it would be easier to have the icon in the taskbar, because I often have a lot of windows opened :mrgreen: )
Re: Password window
Ok, gotcha. I've added your idea to my notes, but I'm leary that it won't work out because of potential side-effects of making that window appear in the taskbar.
Ideally, it would be better if POP Peeper would start nearly instantaneously, and that's something that I plan on addressing for the next major version. That may supercede your need to find the window?
btw, if you're not using v4.1 beta yet, there is a change that improves the loading time, but it's impact varies from user to user.
flechedargent
Re: Password window
Okay, I understand.
