HTML rendering in POP Peeper
Re: HTML rendering in POP Peeper
Glad to know that that was the problem!
It's just by good timing that I suspected that may be the problem -- someone else had a report of crashing a couple weeks ago (although it was a different action that caused it then viewing an HTML message) that we determined to be a memory issue. In fact, in my tests, I'm able to squeeze out a few hundred more MBs of message data before a problem occurs. Certainly the amount of message data is the leading contributor, but there are other factors involved and I'm not quite sure what the "magic number" is -- that's why I could only give you a rough estimate of "1 GB" -- and, of course, that would be the overall size of all the databases and not necessarily from a single account.
I will take your suggestion under advisement, though. It would certainly be a good warning for an imminent problem.
ECourts
Post by ECourts »
I think the key factor here was the inconsistency - different crashes happening at different times in different places in the code. The only common denominator was viewing in HTML which clearly places particular pressure on the process.
Yeah, that's the problem with memory-related issues -- it's rather inconsistent. In my testing, it would usually crash when trying to download too much data (that was the key in the original problem I mentioned), but there were other times when I would try to do something and it would popup an "out of memory" prompt.
