POP crashes on server mesage deletion
fred410
Post by fred410 »
Hello, i have POP Peeper (in Pro trial mode) with no Plus pack added.
(this is windows xp -- yes i know Xpig is not supported)
I marked a mess of messages to delete.
when I do "check mail" the last thing it says its doing is "deleting messages" -- then it crashes.
the basic error dialog says:
AppName: poppeeper.exe AppVer: 4.0.1.0 ModName: imap.dll
ModVer: 4.0.1.0 Offset: 00016c5a
i was able to delete other blocks of messages before but was having some kind of problem (ie. hitting reply button would lockup POP, which eventually would crash program). So i uninstalled it, rebooted, reinstalled.
This is the first time i have tried deleting messages since this new re-install; the reply window now does work.
i have attached the crash trace generated by windows.
Do you have an idea what is happening or what might be wrong? Or what I may need to check?
crash info.txt
(21.09 KiB) Downloaded 315 times
fred410
Re: POP crashes on server mesage deletion
Post by fred410 »
UPDATE:
I "upgraded" to the POP version v4.1 Beta 3 (4.1.0.2003) -- it works !
"check mail" passes the "deleting messages" phase now.
That's exactly what I was going to suggest, so I'm glad you found it on your own and it worked.
There have been several reports of this delete issue, and even though I suspected that v4.1 would fix it, I never had confirmation since most people ended up deleting the messages in smaller batches or from another interface.
