4.0.1 - different versions?
Bilbo
Post by Bilbo »
POPPeeper.EXE both versions 2,273,872 bytes
Code: Select all
Version A dated 2014-12-10 04:55 pm, SHA-256 cb48f4dfdc805febdb447c6f49559bed41a12f8949c4cf0cc6ac2c27f32a0bd0
Version B dated 2014-12-11 12:12 pm, SHA-256 96b81ddf34a5473d90683a7513c97a31827ad9dc8c2b86ad79b5b7b7fb833b23
Should I be worried? How come they don't have different build numbers? Version B has Create-Date of 2015-04-22. If the April 22 / Version B package is just an update to WebMail.dll, how come the main EXE file is so different?
Re: 4.0.1 - different versions?
That's correct, good eye. Luckily, I had written the following note to myself to remind me; otherwise, I probably would have started getting paranoid myself :)
The difference between v401 original is that original contains an older webmail (v4.0.5)
whereas the updated one contains .13
