reported by Gmail as unauthorized intention
bonbonbillo
Post by bonbonbillo »
Get advised by Gmail an intention not complied with modern standard.(this email account I just added into Pop Peeper)
Re: reported by Gmail as unauthorized intention
Hi bonbonbillo,
Sorry to hear you are experiencing the Gmail problem you reported.
If I understand correctly, you are having problems when trying to add a new Gmail account to your PopPeeper Program?
Please post back with the following:
1. Are you receiving an error message in the PopPeeper Program?
(Look for a yellow icon with a black "!" mark in it at the lower right corner of the PP main interface). Click on the icon to display the entire error message text, and then click the [COPY] button - which will copy the message to the clipboard. Paste the message text in your next reply here.
** NOTE: Please make sure your actual email account name (the part before the "@" symbol) is not shown, or change it to something like, "Account X." This is for your security and to prevent spambots from harvesting your email address.
Thank you & best regards,
bonbonbillo
no error message in Pop peeper. Just receiving warning emails from Gmail support team.
Thanks for posting back with that info!
Given the nature of the problem you are experiencing, I have contacted Jeff and asked him to review your topic here. He may need more detailed information and/or logs from you to resolve the problem you are having. This is something often handled more effectively via Support email instead of in open forum.
Jeff should be checking the Forums here later on, and will provide further instructions for you.
bonbonbillo, would you please provide a screenshot of the message that you are getting from Gmail? (if you are unfamiliar with posting screenshots please refer to the following link on how to do this: How to take a screenshot & attach/insert it into your post) Thank you.
bonbonbillo
Yes. attached.Tks.
Translated: "We have avoided an intendo login".
bonbonbillo, take a look at THIS post by Jeff on Nov 12, 2015 9:54 am regarding some settings you could apply.
If your not using IMAP for your "Server type" (right-click on account in left pane of Pop Peeper interface and select "Edit", select "General" if it isn't already and refer to your "Server type" setting) then take a look at THIS post by Jeff on Jul 07, 2015 12:27 pm about using the IMAP protocol.
I would need to properly translate that, but it seems that the general gist of the message is that access was blocked. To be in full accordance with GMail's standards, I would recommend using IMAP and enabling 2-step verification; although, enabling "less secure apps" is also a solution. More information is here:
http://www.esumsoft.com/products/pop-pe ... ilSecurity
(edit: new FAQ created specifically for this issue)
Reason: updated url for new faq
bonbonbillo
Muchas gracias.
