Gmail Error: Try again later. (-10)
douglas9
Post by douglas9 »
Gmail had been working fine until yesterday....and now get the following error on all my gmail accounts:
No problem signing in with browsers Opera,Firefox Vivaldi
Any help or suggestions appreciated.......TIA
Going to error overview have this:
POP Peeper: 4.0.1.0
Webmail: 4.0.25.0
SSL: 1.0.1.8
IMAP: 4.0.1.0
SendMail: 4.0.1.0
AntiJunk: 4.0.1.0
Spell Checker: 4.0.1.0
Web of Trust: 4.0.1.0
--- Web Test ---
Result: 200
Error:
Time: 07:22:20 - 07:22:20 (0 s) (-0600)
Data: Wed, 27 Jan 2016 05:22:18 -0800
[10: GMail] ['imap.gmail.com' (993) SSL: 1] [WebSend: '' (0) SSL: 0]
[10: GMail] ['imap.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1]
tatoo_ar
Re: Gmail Error: Try again later. (-10)
Post by tatoo_ar »
Same error here, also from Jan 26th. POP3 account type works fine.
Tinerfeño
Post by Tinerfeño »
Same for me, POP3 works fine, Gmail do not work.
Error (-10)
MasterAdkins
Post by MasterAdkins »
Same error here. It was working fine last night and this morning three Gmail accounts are failing with error -10. Outlook.com and Yahoo.com email accounts are working fine.
Thanks to everyone for reporting on the Gmail issue(s) you're experiencing.
Welcome to the PP Forums, MasterAdkins.
For anyone else having a similar Gmail problem, please be sure to include the text of the error message you receive (like what douglas9 has in his post # 1 above). Also, confirm if you are able to log-in to the affected Gmail account on-line without any problems.
This will help us narrow down the issue(s) and determine a resolution.
I have contacted Jeff and asked him to look into this problem. As soon as we have additional information on the issue and a resolution, it will be posted here.
Thank you for your cooperation & understanding!
pop_pepper
Post by pop_pepper »
getting same thing, can login online but not pop peeper
mldekker
Post by mldekker »
OS: Windows 8 (x64)
POP Peeper: 4.1.0.3001
Webmail: 4.0.25.0
SSL: 1.0.1.8
IMAP: 4.1.0.0
RSS: 4.0.0.0
SendMail: 4.1.0.0
Chime: 3.0.0.0
Notification Voice: 4.0.0.0
Profile Picture: 4.1.0.0
AntiJunk: 4.1.0.0
Spell Checker: 4.1.0.0
Web of Trust: 4.1.0.0
--- Web Test ---
Result: 200
Error:
Time: 17:45:24 - 17:45:25 (1 s) (+0100)
Data: Wed, 27 Jan 2016 08:45:01 -0800
Gmail [10: GMail] ['imap.gmail.com' (993) SSL: 1] [WebSend: '' (0) SSL: 0]
Onbekende fout: Probeer later opnieuw. (-10)
(Unknown error. Please try again later)
Reason: Last line translated for other members' benefit.
arcadian
Post by arcadian »
Yep same for me too 7 out of 15 not working also computer very sluggish....
Tinerfeño
Post by Tinerfeño »
I confirm:
- Can login online perfectly (Gmail)
- Error Try again latter (-10)
- Pop3 working without problems
WebMail v4.0.26
The GMail issue has been fixed and the update is available. You can either wait for POP Peeper to automatically update (usually within 24 hours) or you can force POP Peeper to manually update by performing the following easy steps:
1) From POP Peeper's main menu, select Help / About
2) Make sure that both of the following checkboxes are enabled:
- Automatically check for updates
- Auto-update WebMail plugin
3) Press the "Check Version" button
- You should see that your "Current" WebMail version updates to 4.0.26
After the WebMail plugin is updated, I recommend logging into each of your GMail accounts manually (using your webbrowser) and that you perform a full login -- that is, if you are automatically logged in, sign out and then sign back in. Then, test your GMail accounts in POP Peeper to make sure that they're working.
In order to avoid issues with GMail changes, I recommend changing your account to use IMAP instead of WebMail. Simply edit each of your GMail accounts and change the "Server Type" from "GMail" to "IMAP" and POP Peeper will make other necessary changes. Note that in certain cases, some people cannot use IMAP because of firewall restrictions, but this is not very common. Also, you will likely need to enable "less secure apps" on each of your GMail accounts using this link:
https://www.google.com/settings/security/lesssecureapps
arcadian
Post by arcadian »
Many thanks as always Jeff - the best there is !! 8) 8) 8) 8)
douglas9
Post by douglas9 »
Many thanks....for the quick fix......
Tinerfeño
Post by Tinerfeño »
Thank yoy very much!!
For me it's working but not using IMAP as server type, still with Gmail, the only one working right. No need to enable "less secure apps" anyway :)
Regards
Matthew Wai
Post by Matthew Wai »
With WebMail 4.0.26, my account using Gmail server can be logged in, but the one using IMAP 4.0.1.0 cannot. I had disabled Windows 10 firewall and tried again, but no luck.
mldekker
Post by mldekker »
Works great again, mant thanks!!!!
MLD.
pop_pepper
works but once a month or thereabout i get the dreaded message "someone has your password" and it all stems from Pop Peeper signing in.
pop_pepper
looks like i have lost three email account because of this issue, getting really fed up with it all now. i've had to change the passwords so many different time i am now starting to lose track of it all. I am gonna look for an alternative way of checking my muliple email accounts because this issue now has resulted in me losing at least 5 accounts. i'm just about fed up of it now :(
pop_pepper
and gmail seemed to have adjusted their forgot email details required, this is a nightmare
pop_pepper
managed to get arund the above by clearing my cookies. Because i have had to manually go into account using the same browser i think Gmail gets it's little brain in a muddle and start asking questions that cnnot possible be answered. however by clearing my cookies it has returned to asking me for my recovery email addresses and i've been able to get into one of the three accounts i thought i had lost. phew
here's hoping i get get the other two back
=D>
Matthew Wai wrote:With WebMail 4.0.26, my account using Gmail server can be logged in, but the one using IMAP 4.0.1.0 cannot. I had disabled Windows 10 firewall and tried again, but no luck.
What error do you get with IMAP? Make sure that you've enabled "less secure apps" as mentioned above. Or see this FAQ for another option:
http://www.esumsoft.com/products/pop-pe ... ilSecurity
