Disable Reply To All
keiser13
Post by keiser13 »
I inadvertently checked the box on the alert screen to use "reply to all" as default.
I don't see where to disable reply to all as the default.
I don't mind using regedit but did not see where/
Any suggestions?
Re: Disable Reply To All
Under the main menu: Tools / Options / General: "Reset confirmation prompts"
Or: edit the ini (make sure you exit PP first; ini file location under Tools / Options / Storage) and remove the line containing "ReplyAllForce" -- this will reset it and prompt you. Or change the value to 0 to disable it.
