Updated to PP Pro by accident - How do I fix it
kolohe
Post by kolohe »
I was updating to v. 4.1 from 4.0. I have previously purchased the add-on pack. I filled out the form to get my Lic. Key. When I got my email, there were URL's to downloads. I apparently did something wrong and downloaded the Pro. So now when I've got PP running "Pro Expires in 30 days" is at the top of the screen. How do I :
1-go back to my original PP but with the 4.1 update and
2-get rid of PP Pro (I don't want to buy it) and
3-keep the updated ver. of the add-on pack?
Thanks for any help you can offer.
Re: Updated to PP Pro by accident - How do I fix it
Assuming that you downloaded the full version which contains both POP Peeper and the Plus Pack, you don't need to do anything. Pro will expire in 30 days, but if you don't want to purchase it, you don't have to and POP Peeper will revert to the free version (the Plus Pack will continue working).
kolohe
Post by kolohe »
Thanks for your help. I do have 1 more question, Is "POPPeeperProPlus-install-v411.exe" the full version? This is the one I downloaded.
Yes, that's the full version. In POP Peeper, you can check under Help / About to make sure that everything is up-to-date.
kolohe
Post by kolohe »
Thanks! Really appreciate the help.
