I can access them via a browser.
Also. If I go Help > About in POP Peeper, it shows that my current Webmail version is 4.1.0.0, but the latest version is 4.0.26.0.Error: Try again later. (-1001)
But, isn't 4.0.26.0 earlier than 4.1.0.0 ?
Sorry, I didn't make myself clear, the History version is v4.0.26 so this is what you will see in the latest version column (in "Help" > "About POP Peeper...") but you are current if you see version 4.1.0.0 (which is the actual file version) in the "current" column, so no need to update.Protocol wrote:Thanks for the tips, lakrsrool.
I still don't understand the versioning number as 4.1 should be higher than 4.0, but I'll update it anyway.
Protocol wrote:Great!
I don't have to go back to my surgeon.
