Suggestion drag attachments
Re: Suggestion drag attachments
You can drag files to be sent, the file will be attached to the email message by simply dropping the file into the message body.
Note from POP Peeper Help regarding attachments:
PP Help on attachments wrote:Files can be attached to your outgoing email if you're using SMTP (attachments are not supported when sending via WebMail). To attach files, drag&drop files from Windows Explorer onto the Send Mail window, press the "Attach" toolbar button or use Insert / File attachment from the menu.
A signature can be added for all accounts or a different signature for each individual account (see below).
In "Tools" > "Options" > "Send mail" you will find a "signature" button to add a signature to all accounts (any accounts that do have its own signature will use this signature) or by editing each account individually (i.e. RIGHT-click on an account and select "Edit account"), select "Send mail" where you will find a "Signature" button for that specific individual account. (btw, there are other ways to edit accounts as well (i.e. select an account in the left account list pane and then from the main menu select "Accounts" > "Edit")
