Issue with one Yahoo account
zorro3210
Post by zorro3210 »
I have several Yahoo account and one has an issue with PP.
I can login with IE, without any issue but this is the message I have with PP
Help me please. thanks
POP Peeper: 4.2.0.0
Webmail: 4.2.2.0
SSL: 1.0.1.8
IMAP: 4.2.0.0
SendMail: 4.2.0.0
Profile Picture: 4.2.0.0
AntiJunk: 4.2.0.0
Spell Checker: 4.2.0.0
Web of Trust: 4.2.0.0
--- Web Test ---
Result: 200
Error:
Time: 14:18:19 - 14:18:19 (0 s) (+0200)
Data: Mon, 22 Aug 2016 05:18:19 -0700
Ybbbtec [1000: IMAP] ['imap.mail.yahoo.com' (993) SSL: 1] [ClientSend: '' (0) SSL: 0]
Erreur ([SERVERBUG] SELECT Server error - Please try again later)
Re: Issue with one Yahoo account
How long have you had the error? ie. as long as you've had the account in POP Peeper or did it just start recently?
Unfortunately, this:
"[SERVERBUG] SELECT Server error - Please try again later"
comes from the server and tells us that there's a problem with your account that POP Peeper likely can't fix. If you contact (support at esumsoft dot com), we can get the logs and see exactly what's causing the error.
In the meantime, you may want to temporarily disable that account, add a new account and set it up to retrieve mail using either POP3 or WebMail. I'd recommend doing it that way so that you can periodically check the IMAP account manually and see if it's working yet (IMAP really is preferrable over the other methods, and it will be necessary for you to keep the IMAP account for diagnosis).
zorro3210
Post by zorro3210 »
I have tried with POP I can access it. but an other issue...
In // I will contact you by mail!
POP Peeper: 4.2.0.0
Webmail: 4.2.2.0
SSL: 1.0.1.8
IMAP: 4.2.0.0
SendMail: 4.2.0.0
AntiJunk: 4.2.0.0
--- Web Test ---
Result: 200
Error:
Time: 10:39:50 - 10:39:50 (0 s) (+0200)
Data: Tue, 23 Aug 2016 01:39:50 -0700
Ybbbtec2 [0: POP3] ['pop.mail.yahoo.com' (995) SSL: 1] [ClientSend: '' (0) SSL: 0]
Erreur ([SYS/TEMP] problem retrieving message.)
Meazol
Post by Meazol »
Jeff wrote: Mon Aug 22, 2016 6:38 pm In the meantime, you may want to give Prosolution Plus a shot and temporarily disable that account, add a new account and set it up to retrieve mail using either POP3 or WebMail. I'd recommend doing it that way so that you can periodically check the IMAP account manually and see if it's working yet (IMAP really is preferrable over the other methods, and it will be necessary for you to keep the IMAP account for diagnosis).
My advice is don't use it with Yahoo, I had problems with it too. I recommend Gmail or your own domain email.
