Slow access to Gmail
Re: Slow access to Gmail
OK, someone sent me some log files and I've been working on this issue. I still don't have any accounts that are affected but it looks like Gmail is implementing a new landing page for gmail.com which looks like this (this is actually the page that gmail.com will redirect to for some people):
https://www.google.com/gmail/about/
Based on the log files I've been provided, there is a test version available:
1) Download this file:
http://data.esumsoft.com/temp/WebMail_v ... _Gmail.zip
2) Exit POP Peeper (main menu: File / Exit)
3) Open the zip you downloaded in step #1 and copy WebMail.dll to where POP Peeper is installed, usually:
or, if you have a 32-bit OS:
C:\Program Files\POP Peeper\
4) Restart POP Peeper
5) To ensure that it's using the updated webmail plugin:
a) go to main menu: Help / About
b) In the list for "WebMail" the "current" value should say "4.2.2.9001"
6) Test your gmail account(s) and let me know if this fixes the problem or not.
tatoo_ar
Post by tatoo_ar »
I just tried the fix for WebMail.dll in the above post and it seems the problem is solved. My gmail-type accounts are working fine now. Thanks!
Thanks for checking and confirming. I'll wait on some more feedback and if all goes well, I'll formally release the fix.
ata
Post by ata »
This fix solved my problems with all of my gmail accounts. Thanks
the_importer
Post by the_importer »
Fixed everything for me as well, thank you.
Just fyi -- the fix was officially released yesterday so you should have it by now if you have auto-update enabled. Webmail v4.2.3 (check under Help / About).
