Reporting spam, blacklist, Bayes
lian
Post by lian »
I just bought Poppeeper Pro to use the antispam utility but I’m a little confused. When I’m reporting a spam to Spamcop, the message is automatically deleted. But is the spam listed in blacklist and Bayes ?
Windows 10 64 bits
Re: Reporting spam, blacklist, Bayes
It is marked as junk (bayes). To confirm this, if you look at the message list (behind the report-spam window, most likely), you should see the red thumbs-down icon appear in the "junk evaluation" column (the header is a flag icon) for that message.
As to whether it is blacklisted depends on a certain setting which is not enabled by default. To enable it:
main menu: Tools / AntiJunk -> Settings
On either the "Basic" or the "Blacklist" page (only one is visible, depending on "Advanced settings"):
- Blacklist email address when I mark message as junk
lian
Post by lian »
OK. Thanks for the precisions.
Windows 10 64 bits
