PopPeeper leaves folders that cannot be deleted
peepinghoward
Post by peepinghoward »
My system is Windows 7 Pro
I have some old PopPeeper data folders that cannot be deleted. There are no files in these folders.
i.e.
c:\netdat\PopPeeper\1 xx-xx@habc.net
c:\netdat\PopPeeper\1 xxxxxx-xx@habc.net
When I try to delete the folder, Windows Explorer says 'Could not find the item'
It will let me rename the parent folder (PopPeeper) but not '1 xx-xx@habc.net'
I originally created c:\netdat\popPeeper and specified this as the DataPath in PopPeeper Options-Storage
PopPeeper created the subfolders
No matter what I do, other than accessing the drive in Linux, I cannot delete these folders.
I have changed the PopPeeper data path to a different drive and re-booted. These folders can still not be deleted.
I have checked their properties and they are not Read Only.
My backup program has backed them up to an external backup hard drive and they cannot be deleted from the backup either. The only way I have been able to get rid of them is by formatting the drive.
No other programs that I use create folders that I cannot delete.
Any ideas?
Reason: Edited to redact personal information for privacy/security concerns (re: posted email addresses)
Re: PopPeeper leaves folders that cannot be deleted
Click HERE where you'll find various detailed methods of resolving this kind of problem in Windows 7.
peepinghoward
Method 2 worked. Thanks..
peepinghoward wrote:Method 2 worked. Thanks..
You're very welcome, glad to hear the problems resolved and thanks for reporting back your results.
This may happen if your account names begin (or end?) with a space. Such folder names can be created, but they aren't compatible with Windows Explorer. POP Peeper v4.1 addressed this problem by preventing that in account names, but it didn't affect existing accounts. If you still have those account names, you may want to rename them (just edit the account in POP Peeper and remove any leading and trailing spaces).
