Mailstore
lian
Mailstore
Post by lian »
Hello, I'm using Mailstore http://www.mailstore.com/en/mailstore-h ... iving.aspx to save my mails. I have to use the pop3 method as I don’t use a supported mail client (only Thunderbird, Outlook ... are recognized by Mailstore and I use eM Client). I’m searching for a way to back up only the mails showing in poppeeper but they seem to be managed in a database - no eml files.
If you got an idea how to make the link between Mailstore and Poppeeper, I’m interested.
Windows 10 64 bits
Re: Mailstore
You can right-click on an account in your account list and select "Archive messages" -- this saves all the messages for that account in .eml format. From the menu, you can then select:
View / Explore -> Archive folder
to see where PP saves the messages.
If you don't see "Archive messages":
From the main menu, select:
Tools / Options
On the "General" page, enable "Advanced options" (top-right)
lian
Re: Mailstore
Post by lian »
OK, thanks. I will have a look.
Windows 10 64 bits
