Hot Key
Re: Hot Key
What happens when you use this hot-key combination (ctrl+M)?
PP Hotkeys can be set in "Tools" > "PPteaker..." > "HotKeys" -- you want to make sure there aren't any conflicts (my "ctrl+M" is used for launch app).
Re: Hot Key
Ctrl+M still works here for Check Mail. Maybe you have some other macro over-riding Ctrl+M (note: system-wide hotkeys typically override application hotkeys, even if the application has the focus)? Try changing it to something else like lakrsrool mentioned and see if that works.
