PP Not Working With Yahoo Mail?
tb75252
Post by tb75252 »
I just downloaded and installed PP 4.4.2. I promptly inserted the credentials of my Yahoo Mail account and proceeded to test things.
PP does not seem to be able to login into Yahoo Mail. The bottom bar shows: Connecting... -> Logging In... And it gets stuck at the "Logging In..." message! I am absolutely sure that I inserted the right Yahoo Mail credentials when I created the account, so I think that the problem is somewhere else.
Is there anything in particular that I must do in order for PP to work with Yahoo Mail?
Re: PP Not Working With Yahoo Mail?
Welcome to the forum tb75252,
As a new member of the Forums, the Esumsoft Team welcomes you and recommends that you review the following Sticky: Information for new users and forum members. This link provides important information about the Forums and POP Peeper as well as additional helpful resources.
As to your issue, please provide us with the answers to just a few questions for now:
1) What company is your Email provider (Cox, AT&T etc)?
2) What "Server type" are you using (IMAP, POP3, Yahoo) for your Yahoo accounts in POP Peeper?
3) Does the POP Peeper Mail Check continue to hang in the the "Logging In..." stage indefinitely (what eventually occurs if anything else)?
4) Please go to "Tools" > "Options" > "Storage" and tell us what your "ini location" and "Data path" displays (copy/paste values to this topic).
Thanks :wink:
tb75252
Post by tb75252 »
lakrsrool wrote:Welcome to the forum tb75252,
Thanks :wink:
I don't quite understand the question. I am using Yahoo Mail which is a web-based email service. I would like to log into Yahoo Mail with PP no matter who my Internet service provider is. Does that answer your question?
I tried both IMAP and POP3. I keep on getting the "Logging in..." message. Eventually things time out.
Eventually it times out and a yellow exclamation point appears in the PP icon located in the System Tray.
ini location: C:\Program Files (x86)\POP Peeper\poppeeper.ini
Data path: C:\Program Files (x86)\POP Peeper\data
Thanks for the additional information, now that we know this:
tb75252 wrote: 3) Does the POP Peeper Mail Check continue to hang in the the "Logging In..." stage indefinitely (what eventually occurs if anything else)?
To help us analyze your problem better, please provide the POP Peeper Error Information.
Refer to the following link on how to post this information to this topic: PP Error Messages: How to view them & copy/paste into your post.
IMPORTANT: Please note toward the bottom of the instructions provided in the above link that you be sure to please edit/obscure any personally-identifiable information that might otherwise be displayed, before submitting the information.
tb75252 -- try using Server Type = IMAP and then press the "OAuth2" button and follow the instructions.
I've done some testing and Yahoo does seem to timeout when you provide invalid credentials ("invalid credentials" is a generic term in this case: Yahoo may not accept your login/password if OAuth2 is required).
Also, this is somewhat unrelated, but this is a concern for other potential problems:
Unless you're using WinXP or you've disabled UAC, using that setting means that Windows won't allow POP Peeper to save settings or data. What I recommend is that you:
1) Exit POP Peeper
2) Move (not just copy):
to:
%userprofile%\AppData\Roaming\POP Peeper\
3) Restart POP Peeper
4) Main menu: Tools / Options / Storage; clear/empty the "data path"
5) Press OK
tb75252
Post by tb75252 »
lakrsrool wrote:Thanks for the additional information, now that we know this:
Voilà:
POP Peeper: 4.4.2.0
Webmail: 4.4.4.0
SSL: 1.0.2.11
IMAP: 4.4.2.0
SendMail: 4.4.2.0
<username edited>@yahoo.com [0: POP3] ['pop.mail.yahoo.com' (995) SSL: 1] [Smtp: 'smtp.mail.yahoo.com' (465) SSL: 1] [Consec: 3]
- Error ([SYS/TEMP] Server error - Please try again later.)
I know for a fact that there is nothing wrong with Yahoo Mail's server because I am able to log into it using Firefox and Internet Explorer.
In the meantime, I think I know what my problem was. Here's the text of an email that Yahoo sent me early on this morning:
Your account is currently not enabled to sign in from apps that do not meet modern security standards (ex. Older versions of mail and calendar apps such as Outlook). As a result, we prevented a sign in to your Yahoo account.
We strongly recommend that you switch to Yahoo's apps such as Yahoo Mail on desktop and mobile and remove your account from all other less secure apps.
If you still want to use an app that uses less secure sign in, go to https://login.yahoo.com/account/security#other-apps and turn on "Allow apps that use less secure sign in". This is not recommended and may leave your account more vulnerable to compromise. To learn more, please visit our help page: https://help.yahoo.com/kb/SLN27791.html.
Yahoo blocked this sign in attempt, but if it looks suspicious to you or it's not from an application that you're using, go to https://login.yahoo.com/account/change-password and change the password for your account.
Sincerely,
Yahoo
After I went to the link and turned on "Allow apps that use less secure sign in", everything went fine.
One more question: Should my server type be IMAP or POP3?
tb75252 wrote: After I went to the link and turned on "Allow apps that use less secure sign in", everything went fine.
The "IMAP" protocol is recommend (either will work however).
Note:
Jeff wrote:tb75252 -- try using Server Type = IMAP and then press the "OAuth2" button and follow the instructions.
If you do the following when using "IMAP" as recommended by Jeff then you would not need to enable "Allow apps to use less secure sign in" (while this will solve your problem, using "OAuth2" provides the best security for you).
The text in parentheses -- "[SYS/TEMP] Server error - Please try again later." -- comes directly from Yahoo's server. While the information they provide is not very informative (nor correct as "trying again later" won't work unless you change the setting you did), the error is likely because your account requires OAuth2 (something that Yahoo has been forcing on users, but they have not done a very good job of announcing), and which the POP3 protocol does not support.
Please see my previous reply for the optimal solution. Using OAuth2 is recommended; whether you want to change the setting back to prevent "less secure apps" is your decision. About the only thing it does is let you know which apps support oauth2 or not.
Something to keep in mind as well and that is by using "less secure apps" you will be randomly getting the following nag prompt from Yahoo if you happen to log-in to Yahoo mail on the web:
You will need to click on the &quot;No, I understand the risks&quot; option pointed out each time you get this Yahoo nag prompt
You will need to click on the "No, I understand the risks" option pointed out each time you get this Yahoo nag prompt
MegaMatt
Post by MegaMatt »
When I click the OAuth 2 button for Yahoo IMAP, I log in via the form that pop up.. I get an error page,.. screen shot attached
tb75252
Post by tb75252 »
MegaMatt wrote:When I click the OAuth 2 button for Yahoo IMAP, I log in via the form that pop up.. I get an error page,.. screen shot attached
I've seen this type of message too. Usually I am able to login after repeatedly trying (on the same device) by clicking the Start Over icon.
I don't really understand why Yahoo sends out this message given that the device I'm using to sign in is the one that I always use...
Is this the same account that you posted about HERE this morning or is this a different account?
What version of Internet Explorer do you have installed?
Based on the screenshot, you may be using an older OS whose supported IE version may not be compatible with OAuth2.
In that case, you'll need to either:
- keep using IMAP, but allow less secure apps so that OAuth2 isn't required
- Switch to webmail (it's very possible that webmail isn't supported on your device since it uses technology similar to OAuth2)
MegaMatt
Post by MegaMatt »
Jeff - Is there any way to force PP to use some other browser on the OS other than the built in IE libraries? I'm using WINE to have PP run on MAC, so for whatever reason Yahoo thinks it can't support the wine explorer browser.. If I install FireFox in Wine, can I force PP to use the FireFox to authenticate and use OAuth/Webmail?
Thanks for all your help!
No, sorry -- it doesn't work that way :)
MegaMatt
Post by MegaMatt »
Ok, then I guess I have to battle with Wine to see if I can get it to login to yahoo mail... Or I guess maybe somehow the webmail plugin will start working again :)
Although Yahoo says they no longer support IE at all... So I'm not sure this is the right approach to take...
Any hints on how PP calls into iexplorer.exe ? Does it just look for certain DLLS to render the window, or does it launch the entire process?
As stated in the other thread: If you stick with IMAP/POP3/SMTP using SSL/TLS (but not OAuth2), you should be fine.
WebMail support for certain providers like Yahoo, Gmail and Hotmail/Outlook is mostly provided for legacy and for a small percentage of people who cannot use IMAP (e.g. restrictive corporate firewalls) -- IMAP is the better protocol, even if you cannot use oauth2.
NPeeper
Post by NPeeper »
We just opened a Yahoo account and wanted to add it to our Pop Peeper accounts but it doesn't work. We tried POP3, IMAP, Yahoo and even Oauth2. Nothing works.
Welcome to the forum NPeeper,
Please provide more details if you can - such as, specific steps you're taking, what exactly happens when "it doesn't work" and if you're getting errors then post the errors in the forum topic etc. (if you're not familiar with how to capture a screen-shot and/or to in general post information to a forum topic - here is a link that may be of some help: How to take a screenshot & attach/insert it into your post or a PM. Specific to "errors" you might be getting, click HERE for details on how to post this information to a topic as well. Also, make sure that you redact any personal, i.e. remove private sensitive, information -- when posting any of this additional information.)
What 1) version of POP Peeper and 2) what Windows Operating System are you using?
Do you have other Yahoo accounts that are working?
Have you tried rebooting your computer?
NPeeper
Post by NPeeper »
First of all, thanks for the quick reply.
See 4 images attached that will answer most of your questions.
Windows 7 64 bit
This is my first Yahoo account.
Just rebooted, no change.
Yahoo error overview.png (15.15 KiB) Viewed 18866 times
