how to get versions to clipboard?
gordon
Post by gordon »
When there is a PP error, you can select the error icon and copy all the versions
to the clipboard. There should be some button to get versions when
there is no error. I searched but could not find.
Re: how to get versions to clipboard?
From the POP Peeper main menu you can go to "Help" > "About POP Peeper..." to get all your versions.
You can also go to "Tools" > "Plugins..." to see all the plugin versions as well.
To get the same interface as when there's an error:
main menu: File / Error overview
and then the 'Copy' button will copy version information to the clipboard.
