Since I ran the Creators Update on Win 10 I have had problems with HTML. I set the default to "Rich Text", then open HTML in messages from known sources. Since the update, opening a message in HTML and returning to the main window locks up Pop Peeper. I have to shut it down and restart it. What can I do to fix this?
Thanks in advance.
Problem since Creators Update
Re: Problem since Creators Update
Do you happen to have Nielsen Online installed?
The behavior you describe is exactly what 2 other people have described, and they both had Nielsen installed. For more information, see this post:
viewtopic.php?f=3&t=6933&p=35017&hilit=nielsen#p35017
Let us know if that's the problem or not.
No, I do not have that program. In the last few days I have not encountered tthe problem (knock on wood).
Ok, glad to hear it's working again. But let us know if you see it happen again.
It's happened again. I am running 4.5 It may or may not have to do with Yahoo Mail. When I try to view Yahoo mail messages in HTML, it glitches. It does not matter if I use Pop3, IMAP, or Yahoo. This does not seem to happen with messages from other sources.
Do you have any messages from before you installed v4.4 that were working and now don't work in v4.5? ie. do you think that there was a direct correlation between upgrading to v4.5 and the problem returning, or do you think that upgrading was just a coincidence?
Can you send me the message source for an email that causes the problem? You can do this from the message list if it's more convenient:
Right-click on the message and then select View -> Message source
This will open the source in your default text editor: save the message and then email that to me as an attachment (support at esumsoft dot com).
The problem predated 4.5, so that is not the problem.Jeff wrote: ↑Tue Dec 12, 2017 7:31 pm Do you have any messages from before you installed v4.4 that were working and now don't work in v4.5? ie. do you think that there was a direct correlation between upgrading to v4.5 and the problem returning, or do you think that upgrading was just a coincidence?
The problem has subsided again. If it returns, I will send the the source info. Thanks for your patience.
Spoke too soon. The prbolem emails seem to be from Redbox to my Yahoo mail account.
I will send the source info.
