Gmail-Raw.dat file created
Apesbrain
Post by Apesbrain »
Whenever I check Gmail with PP I get a "Gmail-Raw.dat" file written to my Win 7 "Downloads" folder. I'd like to stop this. Any suggestions welcome, thanks.
Re: Gmail-Raw.dat file created
I'm currently out of town and cannot check the source code to verify this, but I did a quick test with gmail to confirm -- that file should only be created if you have enabled webmail logging. Press Ctrl+D to access the logger, disable "webmail logging"; enable "save changes"; press Close and press "yes" to the prompt.
Apesbrain
Post by Apesbrain »
"Webmail logging" wasn't enabled, but I enabled/disabled it and the problem went away. Thanks for your quick reply!
