Can't log in to my gmail account get the error message (try again later (-11).
The 'real account" can be accessed...with no problem and other gmail accounts are working fine......
POP Peeper: 4.5.0.0
Webmail: 4.5.1.0
SSL: 1.0.2.11
IMAP: 4.5.0.0
SendMail: 4.5.0.0
AntiJunk: 4.0.1.0 (disabled)
Spell Checker: 4.0.1.0 (disabled)
Web of Trust: 4.0.1.0 (disabled)
[10: Gmail] ['imap.gmail.com' (993) SSL: 1] [WebSend: '' (0) SSL: 0] [Consec: 1]
- Error: Try again later. (-11)
Gmail Error try again later (-11)
Re: Gmail Error try again later (-11)
This error is most likely temporary (transient Gmail Server issue) and as such will resolve itself.
But if not and this same error remains persistent you could try re-authorizing PP for this account. To do this you would edit the account and press the "OAuth2" button and then follow the ensuing steps.
Please let us know if the error is either resolved on its own or if by re-authorizing PP your issue was resolved.
Changed server type to IMAP and everything is fine now.....my other gmail account that is working has server set to GMAIL.....checked a third account that is working is set to IMAP and it is also working.....thanks for your time.....
Your account is set to use Webmail and not Imap, which is why you don't see the OAuth2 button (Oauth2 is only available for imap). To fix the -11 issue, you probably just need to do a full login to the account -- sign into the account with your webbrowser; sign out and then sign back in.
However, using IMAP is the much better long-term solution -- edit the account; change the "server type" to IMAP; press the "OAuth2" button and follow the instructions.
[edit] -- Sorry, I read and replied to your original reply before you edited it. Glad you got it working.
