[solved] problem with a newsletter
lian
Post by lian »
Hello, Jackmail’s newsletter (WordPress plugin) is not scrollable in Popeeper. I told them about the problem but they focus on popular webmail solutions (Gmail, Outlook…). I would be curious to have your point of view – the reason of the problem and if it’s easy to fix. See attachment.
Windows 10 64 bits
Re: problem with a newsletter
Morning lian,
I edited your post because the email source code contains personally-identifiable info, specifically - your email address.
Your topic will remain active here so other members of the The Esumsoft Team can review it and provide their feedback. If you feel it necessary to provide the source code, please send an email to Jeff at: support at esumsoft dot com, describing the issue you are reporting here. (You can include the source code in your email).
Please be sure to let him know you have posted here in the Forums.
Thank you & best regards.
lian
Post by lian »
Thanks Pete - I should have checked this.
Windows 10 64 bits
You are welcome!
Cheers! :mrgreen:
I had posted my original diagnosis and comments here:
viewtopic.php?f=3&t=7078
Something I didn't mention there and thought of this time around -- assuming that you have TB or another client installed, you can use File / Open message in client, which might be more convenient for you.
lian
Post by lian »
Sorry, I completely forgot that I already posted a similar subject.
Windows 10 64 bits
Re: [solved] problem with a newsletter
No problem :)
You mentioned you had contacted them; did you mention that it doesn't work in IE? IE may not be an overly popular browser (~3% overall), but it's still a significant enough browser that I, personally, wouldn't ignore.
lian
Post by lian »
Yes I contacted them and added a link to this thread - well, the other one.
Windows 10 64 bits
