Gmail error
Apesbrain
Gmail error
Post by Apesbrain »
Last success was about two hours ago. Went to the website and logged in no problem. Thanks.
Re: Gmail error
Hi Apesbrain,
If you are still receiving an error in PP, please provide the complete text of the error message via the instructions at the link below. This will help us to see what is happening on your end.
* - Please note the CAUTION statement contained within the instructions above.
Thank you & best regards.
Apesbrain
Re: Gmail error
Post by Apesbrain »
Sorry, here you go...
POP Peeper: 4.5.1.0
Webmail: 4.5.3.0
SSL: 1.0.2.11
IMAP: 4.5.1.0
SendMail: 4.5.0.0
Gmail [10: Gmail] ['imap.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1] [Consec: 10]
- Error: Try again later. (-1007)
[Gmail]
Server size: 0 bytes
Mem size: 0 bytes
File size: 0 bytes
Last DB Maint (global): 03/30/18 11:06:11 (75 days)
Last success: 06/13/18 13:19:17 (225 minutes ago)
Last error: 06/13/18 17:03:50 (1 minutes ago)
Consecutive errors: 10
Re: Gmail error
Try logging into your account with a private/incognito web window. If that doesn't turn up anything unusual, email me so I can get your logs (support at esumsoft dot com).
OR, edit the account and switch the server type to IMAP (and then press the "OAuth2" button), and your days of -1xxx errors will be over. IMAP is recommended over Webmail.
Apesbrain
Re: Gmail error
Post by Apesbrain »
I switched to IMAP as suggested and all is ok again. Thanks!
