PP Pro: Losing activation when deleting or renaming Antijunk.dll
PopTwiddles
Post by PopTwiddles »
Hello, new [paid] user here with a question.
I have set up PP in "portable" mode - no apparent problems, mails seem to be working OK after a brief test.
I have noticed something unusual..... even though both PPeeper and PlusPack are successfully activated,
when I delete [or even just rename] the AntiJunk.dll, the activation status is lost for PP itself.
Pop Peeper Pro is listed as being "Not Installed" in the activation window when AntiJunk.dll is not available, why does this occur ?
(The Plus Pack is still activated in the activation window)
I only wanted the "Sent Mail Viewer" from the PlusPack - the rest deleted without issue.
Reason: Modified topic title for better attention
Re: Q: Losing Activation
POP Peeper v4 needs "something" to be installed for activation -- for Pro, this can be AntiJunk.dll, Speller.dll or UrlCheck.dll. You can disable the plugins under main menu: Tools / Plugins.
This behavior will change in v5 -- you don't need anything else installed to activate POP Peeper. This will allow you to use auto-update to install components you don't already have installed (more info).
PopTwiddles
Re: PP Pro: Losing activation when deleting or renaming Antijunk.dll
Thanks Jeff, that explains it perfectly.
