As of about 5 days ago, I no longer get notifications for gmail. I see the yellow circle with the exclamation point.
Error message reads: SSL connection failed (certificate failed: unable to get local issuer certificate [2] (20))
Is there a quick fix for this? I have V 4.5.1
PP suddenly not notifying for gmail
Re: PP suddenly not notifying for gmail
Hi RichO,
There have been a number of PP users reporting Gmail errors recently.
Please have a look at the following two topics to see if the information/instructions provided in each helps resolve the problem you are experiencing:
viewtopic.php?p=36346#p36346
viewtopic.php?p=36331#p36331
The first is an Announcement by Jeff. The second topic has been an ongoing one which also provides some information/instructions. Please post back and let us know if you were able to resolve your issues.
If you continue to experience the same problem, it is essential to include the entire text of any error message PP may be giving you by following the instructions in the Sticky below:
The complete error message text provides The Esumsoft Team
with additional information needed to assess the problem and determine a resolution.
Thank you and best regards.
It was Avast causing it. The steps in the post fixed it. Thanks!
