Display status in lower left not working
bob1008
Post by bob1008 »
I just moved my Pop Peeper to a new computer (Windows 10). The status in the lower left does not show which box it is checking any longer. The line that says "2 minutes until next check" stays displayed all the time. Even when the program is checking mailboxes and adding messages. I have checked the forums and could not find a solution to this issue. On my old computer this would display the current box being checked.
Re: Display status in lower left not working
Have you tried exiting and restarting POP Peeper to see if that fixes it?
Is it *stuck* on showing 2 minutes? ie. after 1 minute, does it show "1 minute" or still "2 minutes"?
If you press the green button on the bottom-right (which enables/disabled auto-check), does it change the status?
bob1008
Post by bob1008 »
Jeff wrote: Thu Nov 15, 2018 7:06 pm Have you tried exiting and restarting POP Peeper to see if that fixes it?
I feel pretty stupid Jeff. That fixed it. Thank you so much !
