[suggestion] Quick save file
lian
Post by lian »
Hello, I use to save my files in the same directory so it may be convenient to have a quick save button so I don’t have the pop up explorer showing each time.
Windows 10 64 bits
Re: [suggestion] Quick save file
I hear what you're saying, but most people expect some kind of feedback that the action *did* something. So, for example, the "Archive" command does effectively the same thing, except that it saves the message to a predefined location; but you still get a "successful" prompt that you have to acknowledge because it would be ambiguous if it didn't (things I've learned :) ).
lian
Post by lian »
I can understand and I suggest two buttons : one regular and one for quick saving. But I’m not the developer :P
Windows 10 64 bits
