Getting error 1007 with getting gmail. started 3 days ago. running w7 x64.
POP Peeper: 4.5.2.0
Webmail: 4.5.9.0
SSL: 1.0.2.11
IMAP: 4.5.2.0
SendMail: 4.5.2.0
gmail jr [10: Gmail] ['pop.gmail.com' (993) SSL: 1] [Smtp: 'smtp.gmail.com' (465) SSL: 1] [consec: 1]
- Error: Try again later. (-1007)
Gmail: getting error 1007
Re: Gmail: getting error 1007
Hello pluto,
Thanks for including the error message info.
Have you tried what was suggested in March 2018, in this topic when you experienced this same issue then?
thank you, your advice worked.
You're quite welcome. Glad to hear everything's working properly again.
Cheers!
Cheers!
Reason: Modified topic TITLE to reflect Gmail as source of the error code reported.
